shockload »
https://forums.nicoclub.com/shockload-u28825.html
Sun Apr 02, 2006 8:26 am
i am having very bad misfire/breaking up when i stand on it, idles rough but drives down the road fine. my setup includes z32, safc2, dsm 450s, t3t4, running 16 psi on stock ka24e. i switched to blow through mass and left the afc settings alone and it ran excellent . after that i threw in a set of 650cc injectors and took it out on the highway to tune it , i got to to hold an 11.5 a/f on 5th gear pulls 70-120ish but still ran a little poppy in lowwer gears. after some dialing i had it to where it would go strong from 2nd gear but it was still a little rich, i wasnt the one tuning the ecu i was driving we pulled a little more fuel and parked . when i went back out and started the car it had a really crummy rough idle and when i started driving and stood on the gas all the way it started popping really bad and would not accelerate over 5gs so i let off. its been doing this ever since heres what i have done so far looking for problems, swapped the 450s back in, changed coil, disassembled intake manifold and resealed it , checked and tried all afc setting i could find for it, checked for boost leaks, fashed codes 12 and 45 come up and some reason it flashed 3 as well( airflow meter, injector leak) . thats pretty much it also a point of interest , with the 650s it would be running 11.5 a/f and jump to 12.5 on misfire. im fricken stumped and frustrated this makes no sense , any ideas would help out . if i try more **** and it fails i will post. the car will drive around in low throttle and ONLY BREAKS UP WHEN ITS FLOORED OR ALMOST FLOORED.
