early Q injector ohm readings ... strange!
forecast
I ohmed the injectors on my '90 Q45. They are all 2.5 - 3.2 ohms, except a single one at 12 ohms. This reading was taken hot.
From what I've read here, 7 of them seem all very low. Has anyone else had readings like this? Does this mean all seven are bad (argh!)
Dan
Highway Q45
Car: Auto-X, Porsche 944's, woodworking, GreaseSlinger
That's very weird indeed. The reading on my new injector out of the box was 11.8 with the other 7 used ones at 11.9 to 12.1 ohms. With low resistance like that they must pull down a lot more current than the .5 amp Dennis said is normal @13 volts. Are they all OEM? It shouldn't be the heat; but I think I'd try again when they are cold. Good Luck
