audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Fri Jul 11, 2003 3:48 pm
Putting anything other than what came out of it will require the appropriate wiring harness and ECU. If you swap in either you will need a new transmission ( possibly ) too which will probably require an updated suspension to support the differences ( width, heigth of strut towers, etc ) unless the axles have the appropriate length/size and number of splines to work with the new transmission, thus keeping the correct factory suspension. The VQ35DE, being a drive-by-wire would need even more fabrication that may even extend to the speed-o and gauge cluster....
That's a whole lotta work....
