lego126 »
https://forums.nicoclub.com/lego126-u171829.html
Sat Jan 08, 2011 1:00 pm
Ok, I got almost everything worked out. My only problem is th timing, I followed directions on another thread, and got it running, but idle was rough, and distributor wouldn't advance far enoug, so I took oil pump out, moved a tooth or so, and it started good, idled a lil high, but when I drive it, if i'm holding it steady at like 20, and not accelerating, I can feel is sputtering slightly. So I put a timing light on it and, I still am off a tooth or so, cause I cant retard it enough to get the light to come on anything left of 15 degrees. When I advance the timing the truck idles smoother, but high, and it's way to the right of the far right mark on the pulley which is 20 degrees. So now I have it set at 15 degrees second mark from the right, the idlinging is slightly rough, only slightly, but it drives better. Should I let it alone or, take out the oil pump move teeth.. Etc.. Oh and just to make sure, when i'm adjusting the timing, I have to unplug the TPS, right? Thanks ain and orry for tlong post
