Slider4105 wrote:You can't run E85 in the G for an extended amount of time. Ethanol is very corrosive and will eat away at normal engine internals. G's are only capable of taking up to 15% ethanol blend (per user manual).
Using E85 in a gasoline engine achieves lower fuel economy as more fuel is needed per unit air (stoichiometric fuel ratio) to run the engine in comparison with gasoline. The number I have seen is something like E85 being 30% less efficient.
The engine has to be designed to handle the extra ethanol, if planning to run it as a DD fuel. That's why manufacturers have designed the flex-fuel vehicles and badge the crap out of them and sell them at a premium.
Modified by Slider4105 at 1:21 PM 8/5/2008
there is an additive available that can fix the corrosion problem that has been widely tested on other forums and used in the car communities here in MN.
E85 is absolutely about 25-30% less efficient- you have to counter this by adding that much more fuel to the mix (increasing injector pulsewidth and upgrading fuel pump). I understand this and would still come out a bit ahead $ wise.
I guess this is something that really hasn't come up on this forum much (or that you haven't seen).
it is commonly done by various aspects of the tuning community here in MN. My old bugeye had an E85 file, 92 octane file and a high altitude file all made custom on a dyno and it worked very well on the E85 until my brother totalled it. It can save a bit of $, it runs cooler and most importantly (but not so much for my current application with the G) it can allow you to run much more boost without pulling timing (basically like having about 106 octane).
I
