I'm not sure if what you say about the wiring is true. I am using a 62 ecu with a blacktop motor and didn't have to change any O2 sensors or wiring to get it to run.SpeedRacer1 wrote:An E6 ECU is an auto S13 blacktop ECU, a 62 is a manual redtop ECU. The O2 sensor needs to be changed to the older redtop thin style sensor, and the O2 wiring on the ECU plug needs to be changed in order for the O2 sensor to work right. Other than that the engine should run just fine.
