e5 ecu in redtop?
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
ive read posts saying you can use the 62 ecu in the blacktop but can you use the e5 ecu in a redtop?
[TRE05]97ka24DE
Car: 1997 Nissan 240sx KA24DE
i have "HEARD" that they are interchangeable, The only difference is the 02 sensor. If you use a e5 ecu you need a fat sensor. If you use the #62 ecu you need the skinny sensor.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Currently running an E5 ECU on my redtop.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
hijacker, are you running the fat o2? im trying to find out why my car is missing on the 1st cyl. my other post has all the info on it. chime in if you like, i need all the opinions i can get haha
Hijacker
'94 F-150
My harness is a converted KA harness that has ran both 62 and E5 ECUs. The O2 sensor I use is a standard bosch single wire. It's identical to the one used on the KA.
240trackjunkie
Car: 1990 Nissan 240sx
I've swapped a e5 in place of a 62 on my stock redtop. It works great for about 10-15 minutes, then starts running very lean (17-18:1). Any ideas? O2 sensor compatability issues maybe? Not a big deal since it's been running fine with the 62 for 3yrs, just curious why the e5 doesn't work.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
id guess that itd be your o2 warming up causing it to run differently
240trackjunkie
[TRE05 wrote:97ka24DE]i have "HEARD" that they are interchangeable, The only difference is the 02 sensor. If you use a e5 ecu you need a fat sensor. If you use the #62 ecu you need the skinny sensor.
So like this guy said... o2 sensor needs to match the ecu?
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
most likely, but as hijacker said, he has the universal bosch
Jybfan04
Car: 98 Nissan Altima
91 Nissan 240sx
What car does the e5 come out of?
240trackjunkie
E5 is from the s13 blacktop sr20det's I believe.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
e5- s13 blacktop62- redtopand the j4-j5 is s14 blacktop i believe
Hijacker
'94 F-150
J4-J5 is S13 Type X
Sil80315
Car: 1991 Nissan 240sx
who uses O2's? lol ive never ran an o2 on any of my sr's
as for 62 or e5, you can use either or on either motor.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
ah. i stand corrected lol.
copmagnet
Car: 91 240SX coupe
I have a redtop sr20 with the e5 ecu in my car, but it has a skinny O2 sensor? runs ok but has some minor issues I was trying to diagnose (hard start issue, weird a/f ratios) I've had the car only a month so don't know much about it. What O2 sensor is the "fat" sensor? Application, part number, etc so I can get a new one see if it runs better? I tried checking the ecu for trouble codes but the led doesn't light up at all....ever....not sure why.
just figured out why....no led in e5 ecu just found that in a diff post. still wondering about o2 sensor tho.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
iirc the redtops use the skinny (62) and the blacktops use the fat (e5) i dont know if itd have any affect if it were skinny or large, my friend has a blacktop with the 62 ecu and is running a fat. you can always try to see if there is any difference
