E to DE swap
Drift
I have a wrecked 92 240 excellent motor, and a 89 240 that doesn't run. My question is if I can pull out the entire motor/ecu wiring harness, or do I have to splice the wires of the DE harness to the E one?
michael Walters
yes you can! you don't have to splice the DE into the E
Drift
Thanks. Any tips or suggestions? Are there any problems that I may encounter that you or that you know others have encountered when removing the harness? I've just noticed that most who have done it that I've read splice the harnesses instead of sourcing the whole thing and I just wondered why? (Maybe cause it's easier?)
michael Walters
you know what you must save the plug that come off the single cam harness. This plug connect to dash harness and this part will have to be spliced into the twin cam harness
Nissan_Crazy
Car: cars, racin
:help does anyone have a wiring guide as to which wires to splice or is it straight forward splicing?
thanks a lot,mike
michael Walters
i'll see if i can get you one
mackdaddy240
Car: High performance with a clean look.
I have a 90 240sx thats in good running condition, however I want to make my 240 turbo and I figured I should at least get the de and turbo it. Also the 90 pistons raise the compressiong in the de block so do you know anyone who has turbo charged a de and put the e pistons in with a turbo? would I need new rods? I know I'll need fuel upgrades and MAFS but not sure other than that.
Nismo1182
Car: Z06
Nissan_Crazy wrote::help does anyone have a wiring guide as to which wires to splice or is it straight forward splicing?
thanks a lot,mike
Wire it color for color, you will have wires left over, but everything work. Atleast it does in my car.
Nismo1182
Car: Z06
michael Walters wrote:yes you can! you don't have to splice the DE into the E
Ok I spliced the sohc plug on to the dohc harness. But thats not what concerns me. Im more concerned about the 2 plugs by the battery. You know, the ones you have to rewire for a SR/CA swap.
I looked at both the E plugs and DE plugs and 90% of the wires match color for color except for the other 10% of course.
Are both plugs (wires and all) do the same thing regardless of E or DE motor? Regardless of color.
My motor runs fine, no ECU codes (except 55, which is perfect)
But the car sometimes has a dead spot when I get on the throttle and it gets to about 4-5 k rpms. Sometimes the car doesnt have that dead spot.
I was having problems with the MAF before but now its not throwing a code for it, but I still need to try a diffrent MAF.
I just wanted to know more about those 2 plugs. Because right now, my old SOHC felt faster.
~*IdIoT bOx*~
Car: cars
mackdaddy240 wrote:I have a 90 240sx thats in good running condition, however I want to make my 240 turbo and I figured I should at least get the de and turbo it. Also the 90 pistons raise the compressiong in the de block so do you know anyone who has turbo charged a de and put the e pistons in with a turbo? would I need new rods? I know I'll need fuel upgrades and MAFS but not sure other than that.
The E pistons raise to around 11.1:1. You can't run this kind of compression with a turbo. Well you can, but man oh man I don't see anything good coming from that lol.
You actually may want to bump down the compression on the DE.
Altiman94
Car: 1989 Nissan 240SX
If you plan on a turbo and building your motor to support it you would most likely want to go with a lower compression ratio
CiPHeR_Tx
is a DE head on a E block a straight swap or do i need to mod the block at all....keeping the engine N/A
Nismo1182
Car: Z06
~*IdIoT bOx*~ wrote:The E pistons raise to around 11.1:1. You can't run this kind of compression with a turbo. Well you can, but man oh man I don't see anything good coming from that lol.
Diesel engines run high compression 15:1 or more and run a nice amount of boost ;)
easymmkay240sx
That's cuz diesels use compression to combust the mixture.
Nismo1182
Car: Z06
Yup.
andrave
Car: 1989 Nissan 240SX Coupe
ok, whats your point then?
Anyway no the DE head onto an E block is not a straight swap.
CiPHeR_Tx
what needs to be done?
Nismo1182
Car: Z06
http://www.nissaninfiniticlub....40742
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
bump to the top so I can find it...Working on this right now
JustinM
Car: music (live)
Does the check engine light work when you turn the key on? The SOHC cluster doesn't have this light.
