Bigvinnie »
https://forums.nicoclub.com/bigvinnie-u27626.html
Thu May 11, 2006 12:53 pm
There is too much lift involved with the after market cams when used with the E pistons. There are certain clearance issues involved. There is a piston that can be used with no problems at all. This piston came in the 1986-1989 NAPS-Z 24 or known as the z24 or z24i.These pistons have fly cuts in them that allow better use of high lift cams on the DE. It should be a direct fit to the rods, but DeviousKA would know for shure....There is a drop in compression compared to E pistons, I believe something like 10.3:1 or 10.5:1 I haven't done the math so I couldn't tell you what the exact compression is. But they do work.
