Checkered-Member »
https://forums.nicoclub.com/checkered-member-u10193.html
Fri Apr 30, 2004 2:24 pm
1. E-manage
2. Get the pressure sensor (if you keep your stock MAF which maxes out at ?220hp?), and the ignition harness. you'll need the support tool if you have a lap top or the greddy Profec E-01 (which is also a boost controller)
3. You don't need an FMU
you should get a BOV (Blow Off Valve) and a boost controler
