E-manage questions
node
Ok I have searched and found this link
http://www.nissaninfiniticlub....anage
so, my questions is. Can the E-manage pull timing (i.e. pull X degrees of timing under Y amount of boost) or is the adjustment across the board regardless of engine load?
Ideally I would like a piggyback unit to retard the timing more and more for each pound of boost, just like the MSD but somewhat programmable. I know I should go standalone but I have a limited budget. Any recomendations?
node
OK, here is what I found out. There is a table in the E-manage that allows you to modify timeing by engine RPM and air flow. So YES you can retard or advance timing based on engine load.
andrave
Car: 1989 Nissan 240SX Coupe
a guy that used it told me with the pressure sensor and harness it will retard based on timing, but another member of this board told me that it is able to retard under boost without the sensor.I suppose retarding it based on boost and retarding it under boost are different things, might be wise to send an email to greddy and get the answer. and post it here cause I'm curious and lazy.
