E-manage Pressure Sensor?
nismo1003
Car: Ka24de
There are some Pressure sender out there for the gauges such as VDO , can that be used on E-manage as a Pressure Sensor?? Pressure Sender
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
the E-Manage only uses a pressure sensor in case of MAF overrun.
the EManage will not let you convert to a MAP system by itself.
nismo1003
Car: Ka24de
that wasn't what I was asking thou.the pressure sender(VDO) that from the link, can that be possible to use it as a Pressure sensor(made by Greddy) , like i tap the singal line in to the E-manage work as a E-manage Pressure Sensor ...would that work? I'm doing this because I jsut want to save some money 99 bucks (Greddy) compare to 30-40 bucks(VDO).
andrave
Car: 1989 Nissan 240SX Coupe
i don' t know... the common standalone map is the GM map sensor, but I don't know what greddy uses. I would guess you would have to call greddy, and I'm willing to bet that they won't be real helpful, since they want you to buy the expensive greddy one.
