LEMHEAD16 »
https://forums.nicoclub.com/lemhead16-u7080.html
Wed Aug 02, 2006 12:20 pm
I am contributing everything I have learned from this forum in the last three years in the form of E-manage maps. These are the Fuel and Timing maps from my set-up which is currently running 14PSI from a t3 Super 60, 460cc inj, and stock MAFS SOHC KA-T. at 9 PSI I made ~220hp/250tq on the Dyno and have since done some more street tuning (thanks Scelza) to up the boost. I get no knock with 93 octane gas and pretty warm ambient temps in ID.
I am posting these because I could not find anything to help me when I started my project. I love the E-manage but the support for it is almost non-exsistant.
Take these maps witha grain of salt because all setups are different this may make you motor grenade, don't hold me liable.
My AFR's are in the 10.9 to 11.5 range until the stock MAFS maxs out at 14psi from 4500-6000rpm at that point it goes way rich because of the ECU.
On with the show
Additional injection map
Timing
Settings
Datalog file showing maxed MAFS (big picture)
I am using the Greddy pressure sensor so all values are boost dependentEM doesn't use PSI so you have to convert to metric units1 psi = 6.89KPA Map goes all the way to 16 psi
I hope this helps someone. It sure would have helped me alot just to see what a working map looks like
Good luck[
