E-manage install
GTS4-R
Car: my feet
Has anybody installed E-manage in their SR20DET powered 240sx? The ECU wire colors are different from the KA ecu. I refered to the Japanese instruction manual for the ecu pin location on the sr ecu since the american book only had the KA in it so i just cross-referenced to info with the table in the english book....I ordered an injector harness to control the fuel (is this even necessary to control fuel?) I didn't order the ignition harness but they sent one to me with it.....still unsure if i wanna even use it.....but is there any important info I need to know up front before installing this unit? I'd hate to mess something up with my ecu........
180fan
Car: 89 fastback
you should find out how it modifies the fuel delivery into the cylinders. I know the afc uses a modified signal for the air flow to trick the ecu, but not sure how the e-01'll do it. You should check with greddy about that. Ignition harness is going to allow you to modify your timing, I personally wouldn't mess with that, although it'll probably allow for greater control over each cylinder vs. doing it through the cas or distributor for the ka.
GTS4-R
Car: my feet
i don't wanna mess with the timing.....its already SOOOO advanced on the sr motors......
