E-manage Blue Questions
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
I forgot who is running Blue but I have a few questions. SOmeone on here told me on blue you can't run a map sensor for a CA?????? http://www.staticxmotorsports.....aspxUmmm just to verify that wtf???? That means I can run a map sensor on a Blue on a CA right????????
And secondly since there are no harnesses for the CA did you just use an SR one and modify it to work with the CA???????
Thanks
scato
id like some info on this as well.
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
I think it's totally do-able. I just saw it on another site as well. 3 bar map sensor for emanage blue. Everyone on here told me you could only use ultimate to run a map. And being the blue can be had for $200 or less, and run a map on the CA that would be siccccckkkkk!!!!!
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Found this but no answer to map question
zerothread?id=199965
scato
true
damn i forget that prices differ across the country. theres a local guy here in GA selling a ultimate for 200
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Yeah apparently ultimate is better if I could grab an ultimate for $200 I'd do that rather then just the blue. So my other question is.... When wiring in a Map would you just use the wires to the Maf or....???????
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
Boomslang makes a PnP Harness for the E-Manage for the CA18DET. its not listed on their website but they have it. its $239 +shipping.
as for MAP, i haven't seen anything on it. i plan on using the E-Manage but will only use MAP if i decide to go top mount later on.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
imo MAF is better than MAP. i will be running EMB when i get my ecu back, ill be using it for fine tuning and timing control...
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Hey sjb thanks for the heads up on boomslang! That will save me some time for sure!
