e-fan wiring on S13 help...
Type X(J)
Car: '98 240SX SE
hey guys, It's gonna be a 'lil warmer here in the N.East tomorrow so I'm planning to install my e-fan and prepare my hatch for the first time for auto-x season. I've been trying to figure out how to wire my dual 12's in my hatch. I've tried following the instructions seen in the "install" page but with out success. I was going to connect the positive wire directly to the fuel pump fuse, but I can't get the damn fuse to pop-up. I tried using a flathead screwdriver and a small knife to move the clip but it just wouldn't budge. the fuse box is directly behind the battery, right? U'r help is appreciated.
Cyberkreig
Car: 1993 Nissan 240SX SR
You can do that.. but then the fan will run whenever the car is on, needed or not.
There is a FAN relay somewhere in there that you can tap into.. OR you can do what i did. Go to your local autozone and buy a $20 fan controler box. Comes with temperature probe and adjustable knob.
I wired mine right to the battery, so even after i park my fans can kick on and cool the fluid in my radiator if it reaches over my set temp.
Type X(J)
Car: '98 240SX SE
thnx for the reply.I checked in summitracing for the part and found one. I don't think it has a temp. probe. I'm not sure if it's the right one though. Can you tell me if this is it. Thnx
