mmashburn »
https://forums.nicoclub.com/mmashburn-u27397.html
Mon Sep 19, 2005 2:23 pm
so where is your wastegate getting it's signal anyways? this may be the dumbest suggestion on the face of the planet, but this is what i would do:
disconnect the wastegate signal so it wont open at all.... then make sure you keep your eyes on your boost gauge at all times.. see if you can make more that 5 pounds of boost...
can anyone verify that this might work..
and also could it not just be a boost leak somehwere... do you have fmic or side mount?
Modified by mmashburn at 5:40 PM 9/19/2005
