E-BRAKE QUESTIONS
gr8bryt
Car: 2003 Infiniti G35 Coupe 6-MT
1994 Toyota Camry V6 (Sold)
90 240SX SE Hatchback (Sold)
90 240SX SE (R.I.P--12/24/2007)
Hey peeps wuz happenin; I tried searching but couldn't find what I was looking for. I've got a pig nose 240sx and it's my first rwd car so I'm a little confused. My e-brake seems to be weak, as if I have a leaking wheel cylinder (if there even is one ). I noticed it while attempting an e-brake slide and all I got was a progressive decrease in speed. I was going approximately 20mph so I should have been able to get some type of rotation out of the rear end right? Some other things that I've noticed is that unless the hand brake lever is fully up, the car acts as if it wants to roll(not just the normal settling of the car). Any ideas or suggestions would help greatly.
gr8bryt
^^^TOP^^^
rb20det_pwr
Car: skyline hcr32
Basically, your e-brake sucks..If you want a supreme e-brake you can go the complicated route and use one from a 300zx.
The easy route would be to adjust the nut on your handle to try and get rid of any slack. FSM reccommends (sp?) 7-8 clicks to get to the "top".
Also, use quality pads. And since my friend put slotted rotors on his S14 (same e brake as yours) he is convinced that he doesn't need to bother with a R-32 or 300z e brake swap. So if you have a little extra money to spend, you can do that too.
spider_slayer
Car: S14 240SX
S13 240SX
errrr, i say jsut tighten the cable as said abovce and that should be PLENTY to lock up the rear end
......and please make sure your doing all this in a WIDE OPEN and deserted parking lot.
mrzabala
Car: 93 Nissan 240SX SE Hatch
Dont forget to mention not on a hill.
gr8bryt
Thanks folks, I'll be working on that this week. My rear pads look good and I'll be doing the z32 master cylinder later on down the road when I get my 5-lug swap.
rb20det_pwr
Car: skyline hcr32
The master cylinder is a good upgrade and all, but it will not improve your e-brake.
gr8bryt
rb20det_pwr wrote:The master cylinder is a good upgrade and all, but it will not improve your e-brake.
gr8bryt wrote:I'll be doing the z32 master cylinder later on down the road when I get my 5-lug swap.
