E-brake light wont go off!
TheJerseydude
Car: 1994 Ininfiti Q45
My E-brake light will not go off in my dashboard. It doesnt seem to effect anything as far as driving goes. Any advice on how to fix this?? thanks in advance!
Trumpkin
Car: 1995 G50
Of course I'm assuming you have released your e brake! It is either the e brake switch at the pedal or low brake fluid in the master cylinder.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Or of course the alternator.
Q451990
You will typically get the ABS light flickering along with the brake light when it's the alternator. I'd put my $$ on low brake fluid. Remember to look closely since it's possible to have low fluid in one chamber or the other while the other one still looks full.
Heath
TheJerseydude
Thank you all... Yes I definitely tried releasing the E-brake a million times lol... Its not the alternator because I had the alternator go bad on me last year and I replaced it so I would have recognized similar symptoms. I will try the brake fluid check today because I probably didnt check it as well as I could have.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
yes its most likely your brake fluid... Either that or the switch, ive heard sometimes they get stuck.
TheJerseydude
Ok Im gonna do that on wednesday and see if it works. Thanks everyone
