e brake light will not go out
steve 59
hi i have a 90 240 sx with 89,000 miles i bought the car new. the e-light on the brakes came on , i checked the wire to he hand brake and removed it , the light still will not go off. i check the level it good and the brake pedal is hight and fine . is ther a reset on this car to reset the lights i Replace the brakes at 60,00 miles and i dont drive the car during the week, i also removed the wire frome the brake buster and it still stayed on ,can you please give me some help i what to know if i should have to return it back to the dealer to fix this problem or can i fix it my self thanks for your help!!!
steve 59
s13sr20chris
if you have plenty of fluid in the master and ebrake is not on then its a circuit fault. wiggle the connector for the master cyl and see if its messed up. also tap the master from the side with a screwdriver. i have seen them stick(ok so thats not a circuit fault).
PoorManQ45
s13sr20chris wrote:if you have plenty of fluid in the master and ebrake is not on then its a circuit fault. wiggle the connector for the master cyl and see if its messed up. also tap the master from the side with a screwdriver. i have seen them stick(ok so thats not a circuit fault).
Check fluid first. I had that problem in my Q. it took me a week to figure out what was wrong.
steve 59
the car has no abs i checked the wire going to the m/c it locked in good , it is there a fuse or a relay for the brake light?? the brakes work and still is ok . the light came on after i stoped and parked when i got back into the car and relesed the brake the light stayed on .i checked the wire to the brake switch and the switch .can you sent me a copy of the wireing thanks for all you help
s13sr20chris
sure bro 90 s13 e brake diagram. whats your email. if you want to be secretive you can email me at [email protected] and i will reply to you.
steve 59
i sent you my email thanks
