e-brake light
240DRFT
can someone help...my e-brake light stays on even when its all the way down and i think its just the light cuz it doesnt feel like the e-brake is on.
bangstanger
Car: 91 240SX Hatch
I am not sure...because I havent looked at mine yet..but check your fluid level in the master cyclinder. I know in my sentra the brake light would come on if the level was too low...dont know bout the 240...also you can take the time to pull apart the center console and they the cables and switch on the ebrake handle itself. but that takes time..lol..I hope this helps
PGBrian
the light is activated when the e brake kits a little piece that is spring loaded. maybe this got messed up. check it out. see how it works. see if its broken.
Project S13
Car: Nissan 240SX Fastback
My ebrake light has recently started coming on during hard cornering or drifts =p
masticatingcow
Car: 94 Mazda FD3S
Yeah, I hope it's not true for you, but I had the same problem. Brake master cylinder. Good times with that. If it's low, that could cause the light to go on. In my case, of course, I had to replace the whole damn thing. LOL.
180fan
Car: 89 fastback
there's a switch at the bottom of the ebrake assembly.
sanioll
Car: Nissan 240SX SE
Toyota Camry
Project S13 wrote:My ebrake light has recently started coming on during hard cornering or drifts =p
Totally possible, Plus when you brake hard it stays on for a while.
1. this happened to me to couple times. I beileve when brake pads are low on thread, then e-brake light comes on during cornering or hard braking.Might be linked to possible low brake fluid levels due to thin brake pads. Just change them if you can.
2. simply take out the handrest plastic thing in the middle. its held together by a snap on platic border around the shifter and 6 screws. 2 in the front sides, 2 under that snap on plastic cover, 2 on the rear in the mid sides of the seats.
Undre there you will see that button pressed with the spring at the end of the e-brake. check it out, clean it.
hope it works out
SHIFT_240sx
Car: 91 Nissan 240sx SE Coupe
try putting brake fluid in the car. my car's brake light stays on too even if the ebrake is down, but when i put in brake fluid, its goes off, try that before you do anything extreme.
240DRFT
i think its the brake fluid cuz the little thing on the bottom of the ebrake is fine and the fluid is just about on the min line
Asia989
Car: 90 s13.4
ur altenator might be going, samething happpend to me a while back
sanioll
Toyota Camry
240DRFT,
so whats the update on that??
240DRFT
i need to go and buy some brake fluid so i can try to add some and see if thats whats wrong with it
sanioll
Toyota Camry
dont delay anything, just do it, and do it now. unless you play high end games like MinisterOfDoom, and me, you got no excuse. just do it pal.
wow, that sounded like a loser.
sanioll
Toyota Camry
any update?
240DRFT
i havent done anything yet cuz i dont drive it and i lost my license. i get it back in about a month and a half. i'll try to go get some fluid real soon. then i'll let you know.
240DRFT
i added some fluid and a minute later it went off
