E-Brake Light
C1rca
My brake light stay on constantly ive checked to see if it was the e-brake, i dissconected the wires on the e-brake and it still didnt go off. So i checked my brake fluid and i got plenty of brake fluid(last time my brake light was on it was the brake fluid).Now Im totally lost on what it could be.
lok
Do you still have the auto seatbelts? If you removed them unplug and remove the computer. If you have done none of the above then I dont know.
C1rca
Yea they still work, i think it might be my brake pads
steve 59
hay that is the same problem i have the brake work fine but the e light is on ,can any one tell us what is making it keep it on . is there a reset to turn the lite off my is a 90 240 sx with just 89,000 on it can some one please help me thanks
Hijacker
Car: '92 240sx Convertible
'94 F-150
do either of you have ABS? If so, it could be an ABS issue. Have the brakes been acting up, C1rca? Hard to depress the brake pedal? If so, check to make sure that the vac hose to the brake booster isn't disconnected. The only other thing I can think of is that the e brake switch is stuck in the depressed position. Pull the center console and watch the switch as you engage and disengage the switch.
C1rca
no i found out that it was the brakefluid was way low i thought i checked it
