e-brake light
jab11185
Car: 1992 Nissan 240sx
my e-brake light is stuck on....wanted to kno if ne1 else seen this happen b4 and what it means....yes the e-brake is all the way down...and the fluids are in the green too....i'm stumped:confused:
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
If its not engaging the ebrake (just the light thats on) then you have an electrical gremlin. Go fix it! Quick!
TurboKA37
there is prolly a sensor of some sort near the e brake lever. if you take some time to search for it it should be fairly easy to fix.
jab11185
hmmm....but when i cut the wheel real quick the light goes off...would that mean it's probably just a contact point?
TurboKA37
thats weird cuz i think the same thing was happening to my friend's integra. i dont kno if he got it fixed tho
jab11185
the ebrake never worked well neway...i guess i'll just check the cable and stuff....it's 2 late to actually do ne thing...just wanted to find out w/o going under the car...
masticatingcow
Car: 94 Mazda FD3S
I had a similar problem in my 240. And yes, when I turned or hit bumps hard enough, the light bliped on and off. It's probably a loose contact point, which is an easy enough fix. Pop off the center console and start there.
gounc14
Car: 1999 ATX Maxima
I had that problem right after a brake job on my s13, all the fluids were topped off, the e-brake was all the way down...still no go...try filling your fluid reservoir as high as god will permit and then closing it, it fixed the sensor throw for me, the requisite amount of brake fluid seems to be higher than the reservoir lines indicate.
Camel
Car: That would be obvious....
check the float in the reservoir on the stick attached to the cap. if you pull it off and play with the float while the ign is on does the condition of the light change? If it does, put in some more fluid and call it a day. it is probably getting close to brake time for you.
[Zero-S]
gounc14 wrote:I had that problem right after a brake job on my s13, all the fluids were topped off, the e-brake was all the way down...still no go...try filling your fluid reservoir as high as god will permit and then closing it, it fixed the sensor throw for me, the requisite amount of brake fluid seems to be higher than the reservoir lines indicate.
If you need that much fluid to build pressure...are you sure you bled (all) the air out of that brake lines?
navysnail
there is no pressure in the resovouar, the ammount of fluid has nothing to do with the calliper pressure, and his fluid is low, when you turn, it sloshes and turns the sensor on and off. check it for leaks
