silk240 »
https://forums.nicoclub.com/silk240-u50922.html
Tue Jun 16, 2009 1:36 pm
the car i have is a '92 s13 w/ a sr20det motor. the problem is.....
so when the ignition is on, but the engine is not running the e-brake light works as it should. coming on when the e-brake is engaged and going off when disengaged.
but once the engine is running the light stays on no matter position the e-brake is in.
also, the light flickers while driving and seems to flicker along with how i move the gas pedal. and as it flickers there is a static like noise coming from under the dash more toward the side of the clutch pedal.
anyone got an idea cause i have been looking under my dash trying to figure it out.
