E-brake light......HELP!
grob240
My e-brake lights stays on all the damn time.....whats wrong with my car....?
MasterMan
Car: nothing running at the moment city buses "uck here
same here.. when i first got my car it was fine about 3 weeks later it got flaky.. it would go on and off.. and now it just stays on.. i guessing its the sensor.. so it doesnt bother me too much.. might take the LED out tho.. heh
Daunttless
Your thread has been moved.
89sxRCR
Car: destroying self esteem
I had the same problem check your brake line. If there is a leak and your losing brake fluid the light wont go off when u disengage the e brake and its annoying as hell, not to mention unsafe cause ur losing brake fluid. Check your resevoir 2, it might be low
1dollar240
I dont think thats the problem. I have totally stripped out my interior twice. The E brake light sensor is attached to the handle itself. So take out the center console- not too hard, then look at the sensor, It adjusts by turning one screw.
WAbernethy
The BRAKE light is not only to let you know that the E-Brake is on. It also means that something is up with the main braking system. Try checking your fluid level in the master cylinder.
89sxRCR
Gotta be an echo in this room
Two40SX
its a warning for low brake fluid...same happened to me ...when i put brake fluid in it went away
slw240sx
Car: 1990 Ca18det 240sx Hatch
1dollar240 i think you were the only one who read that post right he was talking about the E BRAKE LIGHT the one that goes on when you pull the e brake while the car is on that has nothing to do with rest of the systemn its just a small pin switch that comes loose under the e brake handle an you tighten it up an reposition it an its fixed i know i ve had the same problem.
89sxRCR
ACTUALLY SLW240SX, the e-brake light WILL come on when the brake system is losing fluid. It happened to me, like i said originally, I could look at the e brake light, disengage the e-brake completely and the light would STILL be on. I got the leak patched, filled it with some more brake fluid, and it went off right away. 1dollar240 hit on the OTHER possibility that the e-brake sensor is damaged or loosened. I fail to see any misreading of the post, what is with people on this forum board? READ!!
89sxRCR
grob240, i wish you would respond and say what the hell the problem was so we could see...
slw240sx
i guess i stand corrected i just suspected the light to be on a very simple type of ciruit, do guys have to change you brake pads like every 4-6 monthes ? mine dont last long at all i need to break down an buy some real pads an a 300z upgrade this year
