e brake handle question (seems kinda high)
240Degrees
I have an S13 and is it just me or does the e brake handle have to be pulled up REALLY high for it to work? It's really close to the steering wheel when I pull it up. Is this normal? And has anybody altered their ebrake handle so you don't have to pull it up so high?
stretch240sx
mine has to be at about a 60* angle
Mike09
sounds right to me.
240Degrees
so when u pull it up, its about 2-3 inches close to the steering wheel? (depending on how you adjust your steering wheel)
stretch240sx
well i got my wheel all the way up and its about 6 inches away or so...
midnightshadow
Car: cars, snowboarding, mt biking
the guy i bought my car from owned it since new. and one thing he told me was that before i pulled up on the handbrake i should push the brakes down all the way, then release the pedal after i pulled on the handle. When i do that, the handle usualy only goes up 4-6 clicks. i know when someone has moved my car and they don't the handle is way past 45 degrees.
240Degrees
i think my ebrake goes up unusually high, then.
that180guy
Car: cars&girls...cut the last part out
mine has always gon up that high, looks normal 2 me.......aint it?
specialkonrd
mines like half that hieghtlook at ur ebrake from the fronttheres a lil hole in itstick a 6mm box wrench in there and tighten iti have no idea what a box wrench is heh
240Degrees
cool. thanks a lot specialknord. I just took the ebrake boot off and used a regular 10mm wrench. I think there's only one nut in there that you can adjust anyways. It looks a lot better now. :)
