E Brake Dash Light
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
Is anyone else having this problem? Since I bought the car 2 months ago, everything has been great, but there is a LITTLE RED light beaming in my face every time i drive and its starting to get annoying because i cant seem to figure out how to get it to shut off. The ebrake light just wont go out, I know my friend cory has the same problem in his 89 hatch too and i have a 92 hatch. any clues, even if its just pulling the pod and removing a light, would be great
thanks!
lonelywanderer
Car: 91 240sx coupe
my car has the same problem.... someone told me the switch might be stuck but i never checked it out yet....
MeanGreenS13
if i knew where the switch was, i'd check it out myself
lonelywanderer
Car: 91 240sx coupe
i was told it was under the center console but i'm not positive on that....
naed240sx
Car: .....
Just take off the console portion that goes around the ebrake. The sensor attaches directly to the brake. It is very easy to get to. If you cant get the light to go out by screwing around with it, then I would reccomend clipping the sensor off, and if the light is still on, then solder the two wires together, since the switch is simply an on/off device. Then you will never have problems but ur light will not work. The light is useless anyway imo. Whatever works for you though.
MeanGreenS13
thanks guys
onosqv
Car: '92 240sx Vert
The brake light will also go on if your brake fluid is low. Just thought I'd mention that.
MeanGreenS13
well i just flushed my brake system and put new fluid in it when i did my brakes. so that cant be the problem, and there is only 1 wire going to my brake switch under the console, when i flick the switch, it isnt stuck, but the light just doesnt want to go out. I have a spare gauge cluster here, ill see if the light can be removed easily
naed240sx
Car: .....
the e-brake light? Its completely cable actuated.... so what would brake fluid have to do with it?
MeanGreenS13
i was starting to wonder the same thing lmao
onosqv
Car: '92 240sx Vert
It's overloaded functionality. It is also used to check that your brake fluid is not low/working.
Don't believe me?
Observe the brake master cylinder, there is a 2 wire plug there.
Drain your fluid to around MIN or a little below - or even just push the floating device so it activates the switch.
Look at the cluster - "e-brake light" is on - I believe this is w/ the car in the ON position or once you start the car or something - been a while.
As for the cable actuated part, so that didn't help you when you checked it MeanGreenS13? It's a grounding cable, so if you remove it from the ebrake, the light should be off. If it stays on, the problem is further up the line - i.e. it may be getting grounded out somewhere else along the wire.
MeanGreenS13
yeah im new to nissan, just came over from the DSM camp, BLAH what a mess that is lol anyway, im just gonna pull the gauge cluster and yank the light bulb.
onosqv
Car: '92 240sx Vert
electrical tape is also ur friend, haha.
You can always completely re run the wires heading to the cluster.
You're gonna find a lot more of those "little annoying things" w/ 240's. Have fun.
naed240sx
Car: .....
MeanGreenS13 wrote:yeah im new to nissan, just came over from the DSM camp, BLAH what a mess that is lol anyway, im just gonna pull the gauge cluster and yank the light bulb.
dont do that, would be a waste of time, if the rest of the brake system is fine(mc, etc), just do what I said about taking only the armrest portion of the console off, and clip the sensor on the ebrake, and if its still on, solder the two wires together. If your problem is not solved, you might have a real brake issue
MeanGreenS13
as i said, only 1 wire
naed240sx
Car: .....
ohh, well in that case I would experiment with grounding it but whatever, I think I should just shut up
MeanGreenS13
how bout we just trade cars lol i want a coupe so bad lol
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
I know coups Rock!! and not that many people have them!!! I see 100x more fastbacks!
MeanGreenS13
but the hatch looks better with the widebody =)
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
The hatch looks so much sexier with the widebody kit. I am trying to talk my wife into letting me get another 240sx this time a hatch! I love my S14 but damn a 180 with widebody!
Return to “Interiors”
