ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Sat Jul 31, 2004 9:01 am
I got the RPM to work. I had it on the right wire and everything, even the settings. The E-01 just needed to readjust itself. I had to go back to the "car settings" and change the cyl from 4 to anything else, then it will read incorrect rpm (after reading nothing at all), and when I changed it back to 4 cylinder, it would finally read the correct rpm. I also don't totally understand the boost settings on this thing. Everytime I get it to boost where I want it, it wont ever do it more then once! Sometimes it will hit the target boost then drop back down to stock then target then stock (during the same pull). I didn't have too much time to mess with it as the trip home from work is only a 40 min drive (40 mins of fiddling and still couldnt get it).
