dynos? stock redline?
ATSAaron
Car: cars
Anyone have dynojet dyno sheets/files for a CA with stock cams? Also what is the stock redline on a CA18dET? I've heard 8000, and I've also heard 7400rpm.
Aaron
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
redline is about 7400, but you can rev it to 8000 without any worries. ive got a dyno sheet if you want it, but im afraid my car was running quite poorly at the time so i cant show you anything great. i made 150.97whp and 164lb/ft of torque on about 9psi of boost because my air/fuel ratio was about 6:1.
- tim
rico05
Car: 1992 RMS13 w/ CA18DET
I've seen 8k several times on accident. Don't do it all the time as the oil system is not up to the task, and on anything less than a T3 it is pointless to go higher than about 7k as the compressor is out of its efficency range.
ATSAaron
Car: cars
rico05 wrote:on anything less than a T3 it is pointless to go higher than about 7k as the compressor is out of its efficency range.
Don't worry, I plan to have plenty over a T3.
Aaron
rico05
Good for you;)
pulsar gtr
Car: NISSAN VEHICLES
Stock engine might rev to 7400 rpm, but with every thing being stock, the peak power is at 6800 rpm , so as rico said, there is no point of reving it passed 7K unless you have the internals moded to support it and to have this kind of hp at top ends. A T3 turbo will definitely give you a higer rpm, but keep in mind a good pair of cam shafts will be a smart way to go as well with such a bigger turbo.
PULSAR GTR
boost_boy
Quote »Don't do it all the time as the oil system is not up to the task, and on anything less than a T3 it is pointless to go higher than about 7k as the compressor is out of its efficency range.[/quote] Not true about the oil system not being up to task, but the rest of the post is. The oil pump can handle it and more!
Dee
rico05
Good deal Dee. Just reading some old posts from people with bearing problems and folks blaming it on the pump led me to that assumption.
boost_boy
Something about the engines that UK guys and bearings I assume. The CA18DEs (U.S. spec) are known for bearing failure and that's only because of neglect. The pumps are sufficient, but are not exempt from failing as well.
Dee
r34 gtr
yeah, my engine is proof that it can be done. my friend pegged my tach once... 9000rpm of pain!
and dee, any idea what i can do about rod bolts? i need them by august 3rd. and the head gasket too if possible. ive only got one weekend to get the car together before i go to college and i would prefer if it came with me.
- tim
boost_boy
Quote »and dee, any idea what i can do about rod bolts? i need them by august 3rd. and the head gasket too if possible. ive only got one weekend to get the car together before i go to college and i would prefer if it came with me.[/quote] Your headgasket is here, but I need to go pick them up, so I'll probably be shipping it out tomorrow. As for the rod bolts Tim, why in blazes are you changing them. They are not going to let you down! I don't have a clue as to what the specs of the rod bolts is, but I'm sure if you sent a sample bolt to ARP, they would more than likely be able to accomodate you.
Dee
r34 gtr
yeah, i was mis-informed. i thought i had to change them but the guy i talked to at napa told me they were re-usable. if you can get me the head gasket by the 3rd then i might be ready to go by the time i go to college! w00t!
one last thing, where can i get some oil lines for my gt28? i understand i just need to find them for an SR becase they are the same. just wondering if you could reccomend anyone in particular..
- tim
boost_boy
Use XRP lines and fittings. I'll admit, I never pay much attention to thread pitch in order to scream out an exact #, but as soon as I start reassembling my g/f's engine, I'll be sure to post what the pitch is (Maybe before then).
Dee
GoofyATX240
Let me know also bro heh.
