Heres my setup:minivan_don wrote:NICE NUMBERS!!
can you re-list your setup ??
ive read a couple people getting valve floating when pushing past 20psi on the stock head ... good thing nothing happened when you spiked!
also, could you take a pic of the rad-to-engine clearance ? i know your using the mckinney mounts and i just bought mine but im worried that my fal210 fans wont fit in the tiny space...
there is one that goes from the valve cover to the intake manifoldkrayton wrote:nice numbers....
but please tell me that those oil breathers just dont go into eachother, and they go somewhere else too
Doesn't that one only open under vacuum, during which would be minimum blowby anyway? I think if the one going to the intake tract is blocked, you'd pressurize the valve covers under boost.Kamin wrote:
ehh it takes a little longer than a few seconds of WOT to pressurize the entire crankcase. unless you have LOTS of blowby lolgawdzilla wrote:Doesn't that one only open under vacuum, during which would be minimum blowby anyway? I think if the one going to the intake tract is blocked, you'd pressurize the valve covers under boost.
This was on 93 octane fuel. I do use this as my daily driver except for when the weather is bad (heavy rain). The clutch is a bit heavy in traffic but I have gotten used to it now. The car feels great cruising and when I get on the throttle. It pulls hard and feels like it wants to keep pulling across the entire power band. I havent yet been able to connect my power steering so I havent yet fully seen how the car handles after putting in the engine.OpeLok wrote:What fuel was this on? Pump? Mix? Other? Is this your daily driver? What's the driving impressions of the car after it was tuned? She looks mother effing beautiful BTW. Congrats!
