nice numbers how much torque did it put down and what rpm did you get 223.8??? also do you have a dyno sheet cause i wanna see where and when the sr T25 stops pushing airtm_kickz wrote:I dynoed the car the other day. My best was 223.8whp. I thought that was good for a pretty much stock engine.
CA18DET-SR T25 -Custom 3" down pipe.( sweet as can be... longer than usuall. Extended almost to the mid of my car.)-Dual prof exhaust. 3" tips & two 2.1/2 pipes connected to the end of the downpipe with two test pipes. I hvae never seen this exhaust before. Sounds nice. It was taken off of a r32.
What do you think.
Could you please re-state that, as it didn't make any sense....2BN_S13 wrote:you know if you pull the valve rocker arms and the pole they rock from a USDM CA18DE out of a pulsar and get some more torque numbers right away.
I THINK you mean take the CA16DE intake camshaft..I got one the other day, haven't installed it though, I want to dyno a baseline first to actually see if the mod REALLY does give any gains, but since it actually has 8 more degrees of duration an nearly 1mm more lift I suppose it might..2BN_S13 wrote:sorry, im stupid at night.
You can use the rocker arm assembly from a USDM pulsar ca18de and put it on your jdm ca18det and get some better torque numbers right away. (i think like 20-30 ft/lbs)Just a simple bolt-on upgrade.
CA myth. might add a little because yes they do have different lift and duration, but this has been a long debated CA issue. it really doesn't add a noticeable ammount of anything (no way in hell it adds 20-30 ft/lbs! tomei cams aren't going to add 20-30 ft/lbs)2BN_S13 wrote:sorry, im stupid at night.
WTF2BN_S13 wrote:sorry, im stupid at night.
WTF ?????????????????????2BN_S13 wrote:sorry, im stupid at night.
