Dyno Tuned Boost Designs Stage II Kit
xatracing
Car: 240 bandit
Hey guys, Martin from XAT. Here are some numbers I promised on the stage II kit. I am flat out impressed with the power on this and I have dynoed and tuned hundreds of cars and setups. PJ at Boost Designs did a incredible job matching their new spec turbo for their kit to tha KA24. The dyno chart does not lie.. 8 psi by 3300 rpm !!! 240 foot pounds at 3300 rpm... Recirculated wastegate. The clutch slipped once because it is fresh and not broken in yet .. but it was for a 100 rpm section (loop you see) This power was on 12.1 psi on a E-01 and timing was conservative.. I was running about 18 deg timing at peak boost and a pretty fat fuel curve. This is incredible power that stays and makes the car move all the way 6700 rpm. E-Manage does a decent job but we will be doing rom tunes in the future... and PJ will be offering this with his kits pretuned through Scott (Enthalpy).Will have some stage 1 low boost runs tomorow.
Martin XAT Racing813-875-7223http://WWW.XATRACING.COM
Modified by xatracing at 12:29 AM 3/23/2005
Modified by xatracing at 12:31 AM 3/23/2005
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
I can't see the dyno chart, but the numbers in your post sound great. I'm assuming this was on an otherwise stock block and head KA-T?
Will boostdesigns be able to do custom tunes? nothing crazy, but say nismo 555cc injectors instead of msd 50lb on a z32 MAF?
xatracing
Car: 240 bandit
and yes this was on the 50lps and z32 mafs.
MartinXAT RACING813-875-7223http://WWW.XATRACING.COM
Jeff240sx
Car: Car! Chicks!
Hmph.Check the post on TR.-Jeff
casman86
More like 285whp. The 305 is the spike.
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
285 still impressivve none the less.
anyotherone
Car: '93 S13 coupe VH45
Nice numbers.
What else is done to the car? Does it have a cat? 3" exhaust? Stock block, cams, etc?
Also, what does "CF:Uncorrected" mean?
Thanks!
Jookmasta
ya post the setup of the car and specs of the turbo
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
...and the 'corrected' dyno chart.
- Brian
