dyno tune
IanS13
Well got the car Dyno tuned today started with, 183hp/185tq @ 4psi waste gate spring is 5.8psi so the pressure drop in the ic and pipes made a little over 4psi, and that was running very rich like 10 all over the place. will by the time the a/f was tuned it was around 195hp/197tq @ 4psi. max psi is 8 that turned 230.51/230.17tq
Modified by IanS13 at 8:37 PM 1/29/2005
Modified by IanS13 at 3:14 AM 2/3/2005
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
very nice man very nice indeed
Structure240sx
great numbers
must very nice, huh
crzycav86
Car: 93 Nissan 240SX KAT
That's an interesting curve.
What turbo are you using? What's your fuel setup? and what did you use to tune?
IanS13
the car was dyno tuned, the tuner thinks that i have a vacume leek some were, but some thing is causing the waste gate to drop the boost right around 4k then it goes back to 8psi, so now i have to find and fix the leak then have it retuned. no big deal.
am running t3 50trim370cc 2r injectors safc 2greddy spec 2 boost controllervery large front munt intercooler3" exhaustwalbro 255and lots of other little stuff.
klattr1
Car: GT42R powered S14/KA
what kind of clutch do you have?
MarkEmark
Car: fully-built '95 240sx KA-T
If you're getting a 1.8 psi pressure drop at only 5.8 psi, your intercooler either sucks, you have a leak somewhere, or your boost gauge isn't hooked up correctly.
A good intercooler will have a max pressure drop of 1 psi at a helluva lot more boost than 5.8 psi.
IanS13
the boost controller was offwhen we turned it on the hp jumped from 180+ to 190+ with the same boost
