Dyno Tests?
All things Altima Coupe.
jh3p
Has anyone actually taken their car to the dyno yet? Im sure most intakes will produce the same hp give or take 1-2 hp, but exhausts are different. As for now we are pretty much going off of the sound or appearance. Anyone HP proof?
or claims atleast?
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
a 1-2hp gain could be chalked up to the dyno... need more mods to see for sure...
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
didn't Injen claim like 12hp or something? I personally wouldn't waste $ on a dyno just to find that 1-2hp gain on an intake. Even exhaust you can feel a bit of a response but not that much
LongBeachCoupe
2005 Lexus RX
Psst... incase you missed my rants... injen=crapola!no intake will give you 12hp...
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
12 hp at the engine under a controlled enviornment. They most likely use an inaccurate dyno mixted with a below sea level atmosphere to get those numbers
Team STILLEN
Car: 2004 G35 Coupe
For the record.. do not bother having your CVT's dyno'd.. you'll get a different number every single time.. we've tried.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
Josh@Stillen wrote:For the record.. do not bother having your CVT's dyno'd.. you'll get a different number every single time.. we've tried.
Josh, tried to reach you at Stillen, could you please give me a call when you have a moment, my numer should be there with Alex I believe!
600hppot
Car: full of wisdumb
Have you tried putting it in a certain gear in manual mode? It should keep a constant ratio, no?
kyle@stillen
We spent two days just dynoing our blue V6 CVT A/C and every single run was different. We tried manual mode and all the different possible options and nothing provided back to back results.
You can dyno a CVT but you will not get consistent, back to back results. Sometimes the reading will start at 3500 RPM with a nice smooth curve. Other times the graph will start at 4000 RPM and go straight up.
Like I said, after two days of dyno testing our blue A/C we found that every single dyno run was different. Not one of them could be fairly or accurately compared to the other.
cuzzbubba420
Car: 08 Altima 2.5 S w/ CVT
600hppot
kyle@stillen wrote:We spent two days just dynoing our blue V6 CVT A/C and every single run was different. We tried manual mode and all the different possible options and nothing provided back to back results.
well that just plain sucks.
pakicoupe
Car: 08' Silver Altima Coupe 3.5
well kyle what were some of the #s u came up with on the dyno??
niztec
Car: 2008 AlTIMA COUPE
just wondering, how come you guys at stillen didnt opt for the 6MT?
kyle@stillen
I don't remember exactly what the numbers were to be honest...I'm pretty sure we will be dynoing again tomorrow. I will try to pull up some of the files.
We opted for the CVT because that is what Nissan gave us haha. Also, that is what the majority of the cars are. We wanted to make sure that our parts fit the majority of Altima's on the road.
08Coupe
I could see the graph(power band) being messed up with the CVT but I would think the Peak should still match between runs..Unless the CVT isn't 1 to 1 final ratio..Looking forward to more info, keep up the good work!
NissNEZ08
Car: 2008 Nissan Altima Coupe 3.5SE (Premium Pkg, Tech Pkg, VDC, CVT & Blk Leather)
adidas2go
cvt's, drive ratios (in manual)
Gear ratio 1st gear 2.371 Gear ratio 2nd gear 1.530 Gear ratio 3rd gear 1.110 Gear ratio 4th gear 0.860 Gear ratio 5th gear 0.690 Gear ratio 6th gear 0.439 Gear ratio Reveres 1.766 Final gear reduction ratio 5.173
Dexion
LongBeachCoupe wrote:Psst... incase you missed my rants... injen=crapola!no intake will give you 12hp...
No the WAI's for the 4th gen's give at least 10-12whp. I can link you to another forum that has proven this with members posting up dyno's but than my post would be edited... get my drift?
But if you're going to say its only 5-7hp go ahead because I've seen dyno's (not sponsored dyno's mind you) that prove otherwise. I am also sure I would barely feel 5-7hp but the WAI will give you quite a noticeable difference, exhaust is another story.
This forum member in particular didn't provide any stock dyno's so yeah you can chew me out on that one but with just a fujita WAI he puts down 242whp of course every dyno is gonna put down different numbers but irrc the 4th gen's put down around 230whp stock.
mcheddadi
Car: R8
My intake KICKS MY BUTT. thats how fast it sucks
yeah
