here you go..
Block:SR20DET RedtopWeisco Pistons 88.5mm 9.0:1Benson Automotive Custom Sleeved and O-Ringed BlockCrower Billet RodsCalico Coated ACL Race BearingsARP Main StudsARP Head BoltsSDR Fulley Blueprinted/Balanced bottom End With Polished CrankshaftATI Crank PulleyMoroso Oil PanStock Engine MountsGreddy Style Pulleys
Head:Full Race Head Ported & Polished with Coated Comperssion Chaimbers, done by Dan @ DPR RacingFull Radius Valve JobApexi 1.8mm Head GasketJun Style Intake Manifold with 80mm billett TBGreddy Cam gearsTomei Solid LiftersJUN Valve SpringsJUN Titanium RetainersJun Valve guidesGreddy Rocker arm stopperMoroso Catch Can With -12 LinesBC in/ex 272deg Cams
Turbo/Exhaust:Precision 6765 t/3 billett turboPeak Boost Top Mount Turbo ManifoldSDR Custom Intercooler pipes24x12x4 FMICGreddy Type-R BOVApexi N1 3inch full ExhaustTurbo Smart 38mm WastegateSDR custom SS downpipe
Trans:Z32 TT 5speed with Mazworx adapt kitSingle Pice Steel Drive ShaftExedy Twin Disk ClutchSDR Custom Rear End
Suspension:Tanabe Sustec Pro-SevensTanabe Teas ControllerFOOTWERKS Rear Adj ArmsTien Tie RodsTien tension rodsSPATS Front And Rear Strut Bars
Wheels:Work VS-XX18x9 Front Wrapped with Perreli 245/45/1818x10.5 Rear Wrapped with Perreli 285/35/18
Brakes:Custom Brembo 14.1" Brake Upgrade300zx TT rear Crossdrill and Slotted RotorsKevlar Brake Lines
Fuel System:1600cc InjectorsAeromotive full race Fuel Pressure RegulatorWeldon 2025 race Fuel pump.RCI 12 gal fuel cellSard fuel rail-10 fuel feed line from tank to rail
ECU:Microtech LT10-s Stand AloneWith X4 Ignitor BoxCustom Wire HarnessMSD Baster Coils x4Taylor 8mm Spark Plug Wires
CoolingKOYO RadiatorFlex A Light dual FansRadiator HosesSDR Custom Oil Cooler/Oil Filter Relocation KitSpac pressure release capInterior:
Custom Wrapped SeatsAEM Wide BandAEM Boost Controller10pt Roll Cage Built By Chassis EngineeringPYLE Double Din Radio/TVJDM Digital A/C ControlsCarbon Fiber Glove BoxMOMO Steering WheelGreddy Turbo TimerOptima Yellow Top With Trunk Relocation KitApexi EL Oil Temp GaugeApexi EL Oil Press GaugeApexi El Water Temp Gauge
Exterior:JDM S13 Silvia Front End SwapPiggy Front LipJDM OEM Side SkirtsJDM Rear ValanceJDM OEM Power Fold MirrorsCarbon Fiber Door PillersCarbon Fiber Gas LIDOrgin Style Tail
Misc ModdsSDR Wire TuckShaved Body LineBlended Door HandlesSDR Brake Line TuckPulled And Rolled Rear FendersFull A/CFull P/S__________________Need parts?
http://www.sdrmiami.com
**800hp sr20det powered S13**
I know ramon.. im sure we will be running but we both have things to finish b4 we do that. my car is currently getting painted and some new injectors (235lbs) put in with a new tune..
