my neck hurts too... lol...but besides that...elwesso wrote:All you gotta do now is rotate the pictures so my neck doesnt hurt so bad.....
Looks real good.. 298 HP (is that supposed to be RWHP???) is really stellar... Those headers is what is making your car so leathal... its your secret weapon... I must obtain these!
Great numbers Rob!Actually its 5252rpm so the second graph is dead on. As far as the first, I heard before that if your tires skip or something while on the rollers that might throw off your hp/tq intersection point, but I'm not sure. I'd ask the shop about it anyway just to make sure and since you paid for the run.When's the next trip to Moroso?szhosain wrote:Hmmm ... not to rain on your parade here, since these are great numbers, but shouldn't the hp-torque numbers cross at 5200 rpm? The first curve is off by a lot although the second is closer. Was the system properly set up and calibrated?
Z
Even though its notmy car I tend to agree...rsiwicki wrote:
I am not really interested at this point if I have 290rwhp or 275rwhp due to all the factors that can distort the true number. I think results at the 1/4 mile track should indicate that I am putting down at least 265rwhp...I was doing the dyno to see the shape of the curve and how my HP numbers are basically the same at 4,500 & 6,900 rpms. Anyone who has driven my car will tell you that the car pulls extremely hard all the way to redline without letting off. I think the only thing now hindering the performance on the car is lack of a 5/6 speed auto to get the proper gearing which is something that I will never attempt to modify.
1qckser will post my dyno sheet from my stock Titan.Q45tech wrote:Up to a point headers are like a longer duration exhaust cam, especially with no precats.
Considering a stock rear wheel HP of 210-220 and maybe 240-243 with JWT......... 265 would be great.
Consider that a 5.65 liter Z28 puts down 290-300 rwHP.
Can't wait for Armada/Titan dyno runs.
As Jesda said, there was one, it was on ebay a few times, IIRC it had a plane in the background pictures??FarFetched wrote:... I am just curious has anyone thought about such swap?
I found out the tech at Brewbaker is a god friend of the guys at Pro Performance. Maybe they could "borrow" the Consult for my next run. I posted the Consult results in another thread, Dennis. I don't think they are exactly what I need, but it might be a help. If you can tell me exactly what I need them to print, I can get them to do another run at the dealership when I go back for the last belt change (they were short one yesterday).Q45tech wrote:Try to get a Consult to data log the ignition advance vs rpm during the dyno pulls..................easy to see if KS are pulling out timing if 28 degrees is not accomplished at 6,000 rpm. OR find some 100+ octane racing fuel and add 2 gallons to 8 gallons of the 93 octane pump to reduce KS activity.
110F air filter ambient creates 50F/11F =4.5% lower than SAE STD power [60F] that is at least 12 RWHP.
With a 0.787 correction factor 310=244 RWHP...............I would expect 250-260 Rear lb/ft. Some times spark knock is highest at the torque peak rpm and just 3 degrees retard from 22-24 say 19-21 would result in the power drop shown.
