Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Tue Feb 16, 2010 9:32 am
The only thing I really had trouble with was the wastegate actuator, but it seems like yours is already good to go. When I clocked the turbo i couldn't bolt up the wastegate actuator so I had to modify the t25's one.
Other than that make sure you get the clocking plates for the compressor inlet and outlet. I had mine cut and welded and ended up only costing $50, but I'm sure you can find some used ones for around that price. Good luck!
