Dyno results
98240
This is my setup:garett t3greddy type rstial 10psi wastegatessac manifoldspearco intercooler370cc injectorswalbro fuel pumpsafc 2wideband74,xxx miles on 98 ka24de
I now reach 10psi my only concern is my bov is now gobbling is this normal with a greddy type rs bovred is the first run black is the second
Modified by 98240 at 10:15 PM 4/10/2006
Modified by 98240 at 8:03 AM 4/11/2006
98240
blue is when i had a leak in manifold and intercooler I was only boosting 7 psi
98240
rwhp
98240
this is my afr
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
power looks good, it must feel much faster now. how do you like your car now after all those headaches?
Jookmasta
well i cant get the dyno file to open nor the afr's file to open for some weird reason. mind posting the numbers for hp and torque and what the a/f's were per 1000 rpm? looks like ur making some nice power there. whats the specs on ur turbo as i am also running a str8 t3...................
98240
I fixed them, 229hp to the wheels not sure what it was at the crank. I am not sure what the tq was but I think it is somewhere close 240.
I actually love my car right now. Luckily I am not having any problems right now hope it stays that way for a while.
Toshima
Car: 93 240sx, 93 sc300(m/t)
What is your fuel setup?
Jookmasta
looking good there. ur a/f's seem right on target for the most part. how much timing did u pull? also congrats!
98240
370cc injectors and walbro 255lph fuel pump.
I havent changed the timing yet but i am going to pull it 15*
Jookmasta
o wow this was with stock timing? i'd like to see what u would make at 15 degrees base timing.................
98240
Adjusting timing would really make that much of a difference? I dont know how to adjust timing. I have a msd btm but it doesnt help since i never got wiring diagrhams when i got the btm. I bought it used off nico. I guess i will try to find a shop to install it for me.Is it also normal to have a gobbling noise when your bov goes off?
Modified by 98240 at 2:09 PM 4/11/2006
Modified by 98240 at 2:30 PM 4/11/2006
turbo2nr
Car: 97 240sx (kouki)
nice results
are u using the ssa top mount mainfold?
how is it holding up, did you need to mod it?
98240
The manifold is holding up good no problems yet other then it has this fitting on the side that needs to be plugged up. I just cleaned the inside of the manifold a bit with a dremmel tool to smooth it out a little better.
