Dyno results for the GTR
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
From Autoblog…
It was only a matter of time before the first consumer-owned Nissan GT-R in the U.S. made its way onto a set of dyno rollers. Edmunds Inside Line made the call to Harman Motive, Road Race Engineering (RRE) and Daryl Alison of JSpec Connect to organize a day of data collecting recently for the import from Japan. Harman and RRE happen to each house all-wheel-drive-capable dynos, with a Mustang and Dynapack, respectively. The two units were chosen because they each utilize different means of measuring vehicle power output, making for a range of results that can be more readily used for comparison purposes. And compare they do as a 997 Porsche 911 Turbo and 2008 BMW M3 happened to show up at the testing facilities that very same day, fancy that. Follow the jump to get a handle on the results
The nature of the Mustang dynomometer's design lends it to typically produce power numbers at the lower end of the spectrum. When strapped down at Harman Motive, the GT-R spun its wheels to 406 hp at 6,400 rpm and 414 ft-lbs of torque at 3,800 rpm. The numbers may seem off from Nissan's rating at first glance, but that is only the result of parasitic losses. Large wheels and all-wheel-drive components create rather significant drag on engine output, thus reducing the available power as it transfers from the engine to the wheels. When overlaid with a pull from a 997 Porsche Turbo, recorded earlier on the same day, one can see that the V6 overtakes the flat-6 from 3,600 to 5,700 rpms. While it is nice to come up with high peak values, the real power lies in the area under the curves.
At RRE, the Dynapack's hub coupling design proved to be a source of disdain for the GT-R's drivetrain. The vehicle squirmed in its constraints as the engine soared through its revolutions. Two worthy pulls were accomplished before cryptic Japanese warnings ended the fun. The result came out to be 452 hp at 6,350 rpm and 448 ft-lbs of torque at 3,865 rpm. Standing alone, the numbers are confusing since they are significantly higher than those recorded by Harman Motive. They are also right on the manufacturer's marks despite including loses through the transmission and differentials.
G_whizz
Car: 2010 G37 Coupe Sport
Nice find RN!!
That car is seriously
Wow... 448lbs of torque at 3865 RPM
joe603
Car: 2014 Durango R/T
meh...not really impressed. A twin turbo G puts done similar if not higher numbers. Of course, its RWD compared to AWD. I was hoping that the power numbers from the factory were underrated...
Sil40_Mayhem
Car: 1995 Nissan 240SX 5spd
1992 Acura Integra LS
Nice. Not bad at all for a stock, factory turbo motor engineered for some kind of longevity (and on what I understand to be fairly low boost). I'll take two.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Maybe so, but I don't know if any twin turbo g35 pulling down 3.3sec 0-60 runs...or lapping the ring at anything to look at. The numbers are under-rated. The car is making 450 Wheel Horsepower on a dynojet. Take in account a 25-35% drivetrain loss, the car is easily making 520bhp. Nissan rates the car at 473bhp.
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
RED_DET wrote:Maybe so, but I don't know if any twin turbo g35 pulling down 3.3sec 0-60 runs...or lapping the ring at anything to look at. The numbers are under-rated. The car is making 450 Wheel Horsepower on a dynojet. Take in account a 25-35% drivetrain loss, the car is easily making 520bhp. Nissan rates the car at 473bhp.
WHERE IN THE HELL IS C-QICK????
