whats wrong with the dyno, what do you think is wrong?TheRocket300zxtt wrote:Can anyone tell my why my car is doing this and offer a solution? It should be making far more power for what I have added.
Mods:JWT Single Pop ChargerHKS Hi-Power Cat-Back ExhaustUltimate Z Split Flange DownpipesUltimate Z High-Flow CatsJWT Reprogrammed ECUUnorthodox Racing Underdrive PulleyApollo Racing Front Mount IntercoolerHowe Racing RadiatorTurbo XS Type RFL Bov'sHKS Turbo TimerInjen Intercooler Hard-Pipe Kit
I should be making a lot more power with the mods I have added. And also the huge drop in acceleration at roughly 3,700 rpms on the first run.elwesso wrote:whats wrong with the dyno, what do you think is wrong?
Not yet. My boost gauge should be coming in soon. I still have to check the BOV's like you said before. I think that I will get around to it this weekend.evildky wrote:have you verified what level of boost your running yet?
Yeah I've heard that also, but I think I have lost the washers . The BOV's seem to sound pretty loud still, but I think this would be the easiest to look at first.cville300zx wrote:Check your BOV's. Turbo XS BOV's tend to vent under presuure if you dont have enough washers in them to keep the spring compressed.
Thanks for the great info. How would I fix the wastegate actuators if they are opening at +5 psi? I am going to have to try pressurizing the system when I get around to it. I am thinking that I have a huge leak somewhere as well. I can remember exactly when the turbo's felt weird for the first time. I was merging onto I-83 and I pressed the gas and the car just lurched forward and had no pick-up whatsoever. From then on, it has felt the same way.evildky wrote:-18 is your idle vacume it's suppose to pull vacume at idle and at cruising speeds, as for never going past +5 you either have wastgate actuators that are opening at 5psi or you have a major boost leak happening at 5 psi, I'd say you got a mother of a leak, you can pull the intake filter assy off and install a large plug with an air fitting or schrader valve and pressureize the system to 7-10 psi and the leaks should become very easy to find.
Yeah, that sounds like a boost leak to me! I don't remember, are you still running two intercoolers or 1 FMIC. I don't know much about the Z32 but correct me if I'm wrong, the 2 sides are independent of eachother when running the stock IC's, aren't they? If you have a boost leak or a bad turbo(or wastegate), the other side will still be boosting to a higher pressure. That would make it easier to isolate the problem.TheRocket300zxtt wrote:I am thinking that I have a huge leak somewhere as well. I can remember exactly when the turbo's felt weird for the first time. I was merging onto I-83 and I pressed the gas and the car just lurched forward and had no pick-up whatsoever. From then on, it has felt the same way.
That's a great idea! I will have to try that, thanks!Dagfasho wrote:My freind lost his washers too, I think he uses quarters
