This is produced by the VCT system.DrifterProdigy85 wrote:Can anyone explain the bump in tq from 4500-5000 rpm?
low 11s is the correct AFR in all turbo engines....with 12.5-12.8 ,you will blow your engine....Bwana wrote:
12.5-12.8 at 10psi... looks fine to me.
not nessasarly.... What you are saying is dependent upon timing and also the octane of fuel being ran. Your tuner should know best, idealy its as much timing as a lean as possible w/o any signs of knock for maximum power.... That is if your trying to pump out all the power possible from a setup.al_v wrote:
Better tell Nissan, cause that system they made is going to kill that engine they made...al_v wrote:low 11s is the correct AFR in all turbo engines....with 12.5-12.8 ,you will blow your engine....
What are you looking at?matafied has 275whp with only 10psi and a FMIC. That is 20-25 rwhp higher than a stock RB25 would dyno at with 10psi. He's running leaner- almost 13:1- than a stock RB25 normally does and his power does reflect that. egt's are important with RB25 weak ring lands and AFR's don't directly correlate with egt's. Cast piston and Forged pistons are not the same- if you think you can run the same AFR's and egt's with both go ahead, i wouldn't.Bwana wrote:
While low 11's may be the ideal afr for performance, (I agree, I tune even mildly upgraded engines to run in that range) it is not an ideal balance for a production vehicle. At 10 psi, 216whp and 12.5 afr it'll run a long, long time. He is running a basically stock setup, which would explain the basically stock numbers.
Good times...
If this was a 3rd gear pull, the numbers wont directly compare to most other dyno numbers. 4th gear is 1:1 and is where the car should be dyno'd until traction becomes an issue.matafied wrote: [IMG][/IMG]
stock with just frontmount and mbc 10psi
