i have a gt35 with a 63trim that will go on it eventually . i just wanted to get used to the car, motor and pfc before i did anything. i will have to check the timing at full boost, i just ordered the datalogit kit so all i have to go by right now is the commander. the injectors only max at the 7k rpm range where it goes into the 10's fo afr's.Shocker wrote:Sounds timing related to me. Maxes your MAF and injectors? No way for MAF, and injectors if you a/f's were like 8.0's WOT maybe at that power level.
Whats your timing at full boost?
Also that CR is kinda low... that is a little less than 8:1 after that HG. Your stock turbo like Joe asked right? With that CR you might need a little larger snail and more boost to make better numbers as well.
Oh yeah you dont have adjustable cam gears do you?
ROFL your numbers are finerobbie2883 wrote:yes, stock t28
i don't have the q45 maf on there. just the stock r33dftsilvia wrote:there is no way ur maxing out a Q45 maf with a stock t28.
u might have a bad maf or something isnt hooked up right
