A wideband is a sensitive oxygen sensor that can tell what the exact air/fuel ratio is. Most dyno shops use a sniffer that attaches to your muffler now. Anyway, a turbo car on pump gas should generally be around 12:1 air/fuel ratio. A lower ratio like 10.5:1 would indicate a rich condition, and a 12.5-13:1 would indicate lean. You always want to start rich and lean it out slowly without getting any detonation. When you do a dyno pull, the computer will map the A/F ratio along with the RPMs. You just adjust the area that is not at the desired ratio.DjLiquid wrote:I know alot about cars and engines but everybody always has to learn something new otherwise they'll always be missing out. My question is dyno related.
What's wideband and how can you tell how to tune your car from a dyno sheet to make it run better?
There is really no set a/f. On the dyno, you can find out what your Rich Max. Brake Torque and Lean Max. Brake Torque.c-rad wrote:Anyway, a turbo car on pump gas should generally be around 12:1 air/fuel ratio. A lower ratio like 10.5:1 would indicate a rich condition, and a 12.5-13:1 would indicate lean.
Wideband is 0v to 5v, and ~9.5 to ~20 a/f.81na ZX wrote:A "Wideband" O2 sensor will read 0V to 4V and is accurate between ~10:1 and 16:1.
TYPICALLY, turbo cars run a high 11 low 12 A/F ratio on 93 octane. You'd be hard pressed to find a turbo car running 13:0 or greater A/F on 93.Turbogixxer wrote:There is really no set a/f. On the dyno, you can find out what your Rich Max. Brake Torque and Lean Max. Brake Torque.
I disagree. Whether you are running race gas or 93 octane makes a HUGE difference. You can get away with a leaner mixture running race gas because it is less susceptible to knock.Turbogixxer wrote:BTW, there is no different in a/f on pump and race gas. You can not run race gas lean because it is race gas. All octane is, is the resistion to knock.
Ask yourself this. What makes the difference between running low 11's in boost, then running what you said? Or running a leaner mixture?c-rad wrote:TYPICALLY, turbo cars run a high 11 low 12 A/F ratio on 93 octane. You'd be hard pressed to find a turbo car running 13:0 or greater A/F on 93.
Disgree with what? Research what octane is. You will gain more power with more timing (thus more octane needed) then leaning the car out.c-rad wrote:I disagree. Whether you are running race gas or 93 octane makes a HUGE difference. You can get away with a leaner mixture running race gas because it is less susceptible to knock.
If you can not understand/answer my question(s), then you say he is right with NO reasoning.slownslurious wrote:I don't know what your first question is asking
Why can you run leaner on race gas? What is "techincal" answer? What is more power? 1whp? 5000whp?slownslurious wrote:C-rad is technically correct on the fact that you can run leaner on race gas, and it usually makes more power that way
I think you are arguing with things you do not understand. Opinions are cool, eh?slownslurious wrote:I think you are arguing things that aren't being disputed.
No reason to post without explaining what you stated.slownslurious wrote:no need to be an unreasonable fellow.
