Thanks sir. I'm not trying to be a d!ck it's just I've had bad experience when I ask for something specific and people ask questions and then get off topic when I answer them with thier opinions. I just wanna SEE it myself. If/when you can show me the dyno graph, let me know.So thanks for understanding.minivan_don wrote:well its not my opinion ... i actually i have a gt35 .82 ... it works VERY well but im considering of buying the .63 ar for when im on the streets. just thougt id give you my feedback
im also waiting to use my dyno graphs for the "luanch" of some custom grind rb25 cams
good luck!
Modified by minivan_don at 7:51 PM 9/2/2007
I actually did that already (remember the part where I said I was debating between two different turbos - how do you think I got to those two?) and while it'll definitely tell you how efficient (which is what a compressor map will tell you - how efficient a turbo is - provided you know the pressure ration and corrected mass flow) the turbo is. It WILL NOT tell you how and where the turbo will spool.I did all the work myself here man ... If I needed compressor maps and **** I'd have asked for them here or went and looked for em myself (actually I did) I'm dumbing it down here I'm only asking for what I need.Which is why I'm looking for dyno graphs... I'd like to see WHERE the .63 hotside A/R will spool in comparison to an .82 A/R hotside.Also I'd like to see what whp levels are seen at what boost levels.Kansei240sx wrote:Why dont you just get the trims of various ones you want, look at compressor maps and then calculate it based on the displacement of your motor.
Instead of going of peoples dyno charts, its best to have some math and better knowledge behind your decision.
The GT35R is a near perfect turbo for this motor because its surge line is near just straight up, but there are different trims that make it different than the next. I'd just go plot away, i know i am for my setup.
Oh that'd be awesome!is it skylineaustralia.com? or whats the website address?Thankseh? wrote:Try skyline australia forums. They have a thread with just RB25 dyno graphs.
Im sorry, when did i call you stupid? I just made a suggestion and then you got all upset. I am not spouting off at the mouth. If you do the right math, and add the right variables, you can make at least a good estimation of where the turbo will begin to spool. You can also calculate how much power you can make where. You cant just get it by looking at the compressor map alone, the engines VE plus the Air in lb/min. It is possible to find the spot on the map that the compressor will operate at the instant your engine is at the given (power & boost) operating parameters, thats what i was trying to tell you.RideZX6R wrote:
So instead of spouting off at the mouth about compressor maps acting like I don't know what the **** I'm talking about (or trying to act like YOU know what youre talking about) ... How about you shut up or simply show me YOUR dyno graph with a 35R on a RB25 and then tell me the specs of the turbo in specific, unless of course, you don't have one?
.70A/RRideZX6R wrote:Right on.What's the A/R of the turbine side?
Sorry sir, I get annoyed when people think post count = knowledge.I read and do a lot more than I post. I liek SEEING dyno graphs because when doing caluclations variables will change things too much (intake mani, cams, exhaust mani, etc) so I like to SEE the results.Kansei240sx wrote:Im sorry, when did i call you stupid? I just made a suggestion and then you got all upset. I am not spouting off at the mouth. If you do the right math, and add the right variables, you can make at least a good estimation of where the turbo will begin to spool. You can also calculate how much power you can make where. You cant just get it by looking at the compressor map alone, the engines VE plus the Air in lb/min. It is possible to find the spot on the map that the compressor will operate at the instant your engine is at the given (power & boost) operating parameters, thats what i was trying to tell you.
You dont need to take offense, its the internet man.
I plan on spending the Cash for a AEM EMS or using GReddy Emanage Ultimate with all the sensors/harnesses for the car. More than likely AEM cuz I've used it before and I like it.No cheap S-AFC BS.I'll likely take it to Evans Tuning (great tuner) for a tune.Kansei240sx wrote:One of our locals made 507 rwhp
T71Its either a stock or freddy manifoldsafc2AVC-R550cc injectors15psi
Stock block and head gasket. They tuned with the SAFCII and it ran that 15 psi
Within 24 hours of the dyno he got greedy and blew the motor because he upped the boost to 19 psi and melted one of the front pistons.
He also had an RB20DET Making 386 Rwhp on the same mods list, minus the manifold on an IHI RHC6 turbo.
The guy is notorious for having a retarded fast car and then blowing it up just as soon as it's done, that or it lasts a few weeks.
Just janky tuning.
wonderfulcoreansurfer wrote:which turbo mani are most people going with?
i've been looking into it, but besides the fullrace one, the others have clearance issues with the steering column.
