usdm_180sx »
https://forums.nicoclub.com/usdm-180sx-u12076.html
Fri Oct 17, 2008 5:08 pm
• S14 SR20DET Front clip • Air Conditioning with JDM Digital climate control • Apex N1 exhaust • CP Pistons (86.5mm Bore, 8.5:1 CR) • Eagle Rods • Apex 1.1mm head gasket • ARP head studs • ARP exhaust manifold studs • Blitz FATT turbo timer • Blitz Stainless Steel downpipe • Blitz SBC iColor Boost Controller (With wideband a/f and water temperature gauge) • Exedy Hyper Single clutch • Kazama Stainless Steel 80mm test pipe • Greddy catch can • Greddy valve springs • Greddy rocker arm stoppers • Greddy intake manifold • Greddy racing suction metal intake pipe • Crower titanium valve retainers • Greddy S14 hotpipe • Greddy RSPL HG FMIC • Greddy SR20DET Turbo Extension • HKS GT-RS turbo • HKS 256/264 step 1 cams • HKS stainless exhaust manifold • HKS FCon VPro Fuel Computer professionally tuned by HKS • HKS Universal Power Flow filter • HKS mechanical boost gauge • HKS SSQV Blow off valve kit • Optima Yellow Top Battery relocated to trunk • SAMCO upper and lower radiator hoses • SARD adjustable fuel pressure regulator and fitting • Signal Auto Radiator cooling panel • Tomei/NISMO 740cc injectors • Tomei fuel pump • Tomei 70mm Throttle Body • Yashio Factory brass Radiator
