Dyno'ed today...Im assuming these are averga numbers
chicos240
Car: 1995 240 SX
I just finished my swap and was eager to get a baseline before I start eating cap n crunch in order to afford more mods.Its sr20det s14 3"downpipe that came with Clip2.5" exhaust (crush bent)Iridium plugs
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Thats decent numbers for stock. 3" Catback will probably give you a good 10whp more.
TKOcrewSR
Car: 1990 nissan 240sx
they are pretty good numbers for stock i dynoed at 193hp and 191tq when i was stock. one thing to always remember be able to support the horsepower b4 you make it.
Chezedik
Car: 1991 Nissan 240sx
Looks fine to me, were you hoping for more?
hstylez
Car: 1993 240sx Fastback
seems reasonable. the exhaust is probably robbing you of a lot of power. ide be willing to bet a 10hp gain with a mandrel bent 3" exhaust...
FSUDrifter
Car: trying to decide on one...
was that stock boost?
chicos240
Car: 1995 240 SX
explain support?
chicos240
Car: 1995 240 SX
I was expecting 200, but i guess 192 is pretty close. its probably the exhaust thats killing the 200
chicos240
Car: 1995 240 SX
You know, you may be right. Going from a 3" down to a 2.5" catalyst and a crushed exhaust may be enough backpressure slow those last few hps down. The only problem is finding a 3" exhaust that looks stock, (2 medium pipes) and that also sounds close to stock. While at the same time not sacrificing performance.
chicos240
Car: 1995 240 SX
Yes, I have not put on my walbro fuel pump yet, therefore I have not put on a manual boost controller, which then leads to a FMIC and then that leads to bigger injectors, which then leads to a better exh mani...etc etc...SO i kind of wanted to make a run, catalog it> throw some upgrades>make a nother run..etc
IDriveFords
Car: 93' Nissan 240sx
Those are pretty good #'s for stock. How much boost were you running b/c that means alot too. I'm guessing you were around 8ish 9ish psi?
rushtillyoudie
DrifterProdigy85 wrote:Thats decent numbers for stock. 3" Catback will probably give you a good 10whp more.
can you post ur list of mod? im planing to build a SR this summer and i want to see what every one has. how much boost can a stock sr internal can handle
corey240
Car: 1993 Nissan 240SX Base Drift Machine
you dont need an after market exhaust mani, they dont make that much of anything but bling. just because you have an after market fuel pump doesnt mean you have to upgrade everything els, you shoulda put the fuel pump on already with the swap.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
chicos240 wrote:You know, you may be right. Going from a 3" down to a 2.5" catalyst and a crushed exhaust may be enough backpressure slow those last few hps down. The only problem is finding a 3" exhaust that looks stock, (2 medium pipes) and that also sounds close to stock. While at the same time not sacrificing performance.
Have you look at the Circuit Sports exhaust?I'm not sure how it sounds, but it attempts to retain the stock look. It is stainless steel and 3". Worth checking out and several sponsors carry it.
corey240
check this out, this guy made some decent numbers off a couple small mods, should be about what i have inh p numbers for my own mods.
http://forums2.nicoclub.com/sh...65402
fixed
Modified by corey240 at 11:46 AM 4/16/2007
homeslicej2
check what out?
goj_cloud
corey240 wrote:you dont need an after market exhaust mani, they dont make that much of anything but bling. just because you have an after market fuel pump doesnt mean you have to upgrade everything els, you shoulda put the fuel pump on already with the swap.
who told u a after market exhaust manifold doesnt do anything but bling athat is not true at all. if you get a bigger turbo a exhuast manifold will help alot in turbo spool time/lag.
homeslicej2
While this is true, unless you get the cheaper manifolds (like a Megan) I would recommend extrude honing your stock mani. It gives you the same benefits and shouldn't cost too much. Talk to WDracing for a how-to. He'd be willing to help with that. I'd go with the exhaust and a turbo elbow upgrade before I worried about the exh mani.
corey240
b
homeslicej2 wrote:While this is true, unless you get the cheaper manifolds (like a Megan) I would recommend extrude honing your stock mani. It gives you the same benefits and shouldn't cost too much. Talk to WDracing for a how-to. He'd be willing to help with that. I'd go with the exhaust and a turbo elbow upgrade before I worried about the exh mani.
ngo was his nam- o-
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
Those are decent numbers.
homeslicej2
corey240 wrote:bngo was his nam- o-
corey240
im tired!
homeslicej2
me too!
