Dyno'd today
forsaken
Car: cars, music, pool
Its a basically stock redtop with an A'pexi intake. I dynoed at ATP in Fremont on a Dynojet.
First pull: 168.1/165.2Second: 161.8/159.7Third: 163.2/161.2
The first two were back to back and the third was 5 minutes after the second and the temp was in the mid 80s.
Overall Im pretty happy with the results, the only thing that worried me is that it showed that I was running lean... which I cant figure out why on a stock motor.
I'll scan the graphs later when im not lazy.
minoru
what are your mods?
I put out 145.6 hp and 149tq max running super rich, I think I have 550 injects (not sure came with motor along with chipped ecu to run these). oh yeah I dyno'd at the same place.
forsaken
All I have is an A'pexi intake and a C's short shifter.
minoru
oh yeah what gear did you do your runs in? I did mine in 3rd gear.
1st run: 3rd gear 145hp 149tq2nd run: 4th gear, wastegate disconnected 180hp 197tq3rd run: 3rd gear wastegate disconnected 174hp 185tq.
all runs were very rich even with the wastegate disconnected the air fuel ratio didn't change at all.
vboyq
forsaken, was that on at stock 7psi?
forsaken
Mine were in third as well. Although I havent touched my boost it shows that its running at 8 according to the boost gauge but Im not sure how accurate that is.
vboyq
wat else do u have on ur sr minoru?
AznRide
Car: Cars, hondas, import cars, girls, cars, girls, girls, and more beautiful girls.
Tell me, this guy that i raced this weekend has a S13 with SR redtop, T28 and tuned at 14 psi with SAFC and he said he made around 270 HP...I don't know if he's lying because I was pulling on him all 1st and 2nd gear, but he zoomed by me at 3rd gear pretty nice. I was running only at 10 psi.
chrispy
Car: 1990 Nissan 240SX HB
he would also have to have bigger injectors , and a didn't MAF, because i think they both max out at around 240.
Altiman94
Car: 1989 Nissan 240SX
Those numbers seem a bit low. Sr's are rated at 205 from the factory (crank), that should put them at about 180-185 rwhp with a 5 speed. I don't undresatnd why you all are losing over 50 horsepower to wheels from the crank.
forsaken
wheres your math at bro? i lost 37hp. RWD cars have between 15 and 20 % drive train loss. I had about 18% which just about right. Considering i was running a little lean its not bad at all i think.
AznRide
I got my car dynoed too... here are the results.
Made 180ish HP at 7 PSIMade 208 HP at 10 psiand Made 232 HP at 14 PSI.
Upgrade, Walbro Fuel pump, FMIC, Downpipe, exhaust, and SAFCII
nrcooled
Car: cars, duh
I am maxed out on bolt-ons:
FMICN1 DualDPFilter(and a couple more I can't remember)14lbs of boost
230hp 252lb/ft
My first dyno run was with teh SMIC and 9lbs I made190hp 205lb/ft
I have charts of both if anyone is interested. Both of your numbers seem pretty low though:( Did you get your A/F done?
minoru
All my mods came with the car except for the lsd, and the boost gauge. currently I have a 3in. down pipe connected to the stock exhaust. The car also seems to have larger injectors and a chipped ecu to run the injectors. The runs done with the waste gate disconnected resulted in a 1 bar pool in 4th gear, and .8 in 3rd gear.
14.7 psi = 1 bar
