Slideways^Jordan »
https://forums.nicoclub.com/slideways-jordan-u73752.html
Mon Dec 03, 2007 9:31 pm
When i first dynod my redtop SR i had also dynoed my car on a DynoDynamics and ran the exact same setup you have on your SR, but i had the boost set for 10 lbs and it peaked to 12lbs on my hks actuater. Well after 3 pulls i put 202.2HP to the wheels at 5800rpm and 190Ftlbs of torque at 5300rpm.
and yes if you run a stock motor with stock ecu and injecteres with the boost higher than stock setting the AFR is going to be off.
A Dyno Dynamics Dynamometer is one of the lowest reading dynos out their, IIRC it is the lowest reading dyno out their.
Hey usdm_180sx did you have a standalone when you dynoed your SR because your graph looks real rough
