TDot »
https://forums.nicoclub.com/tdot-u191641.html
Fri Apr 12, 2013 3:02 pm
Let me preface this by saying I dynomated mine before I put in my sub, so I can't really comment on the contrast of with and without the dynomat with the present setup.
I bought the dynomat because I figured once I upgraded the sub I would absolutely need it, however I really didn't hear that much rattling beforehand...taking that with a grain of salt because most of the times the stock sub is a weak performer due to how infiniti set up the crossover processing. Their efforts to stop vibrations is at least one positive I can say with this car and the audio quality, the car seems to be pretty well built in not rattling or resonating. 2008. They actually have their own damping material in the trunk and in the doors that seem to work extremely well. The thing I believe should really be paid attention to is the rattling not the resonating(which is what the dynomat is really for). The places where things are touching each other and vibrating against each other. Ex. after all the money spent on dynomatting the car, the rear license plate with cover and the button that pops the trunk almost puts it to waste.
What I would recommend is to take everything apart first (rear deck, license plate, trunk liners, spare tire, door trim) and play your stuff and isolate what is actually in need of the dynomat. Leave your trunk open when you do this the first time. One place I can say will almost certainty need it is the inside of the door panels by the handles.
As far as the holes in the trunk lid, I don't recommend you just cover them up, either fill in the holes or dynomat inside the cavities and outside. By covering up the holes (without filling the cavities with some type of foam or something) you are creating a chamber for the waveform to resonate, and you don't want that. Also remember that you do not need to cover every piece of metal. This is to stop the resonating from traveling through the metal causing waveforms, so figure you really only need to cover 30-50% of any surface. Save most of your money for sound proofing and stopping vibrations, the car seems pretty well built....again this is with a gain of salt.
