IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Thu Jul 29, 2004 4:01 pm
thats a good way to do it. even if you have the normal wire going into the tank, the current doesnt have to flow through small wire the entire length of the car.
sediment has alot to do with dying fuel pumps. but, on the other hand, the walbro pumps are small to begin with, and have to work very hard.
the TT pump will definately outlast a handful of walbros, and will pay off in the long run. or the time it takes to kill two walbros.
i would say that even without doing a rewire, 600cc or so injectors can be fed without worry.
you could go higher than that, but its not good to push your luck with fuel. you also have to take into account the pressure drop from the filter, fuel lines, ect.
if the pump can supply about 930cc at 13.2 volts, then it would be safe to figure a 35% margin to account for voltage drop through stock wiring, and the restriction of the fuel lines and fuel filter.
thats about 600cc injectors with the above margin. perfectly safe considering you shouldnt run your injectors at 100% DC anyway.
if you run more than 600cc's, than a rewire would be a good idea to achieve full power at the pump.
